Optimum idle setting?
Guest bastaad525
Guest bastaad525
What do you guys set the idle at on your L28ET's? What does the factory set it at? I used to try to set it at like 650rpm, but the car really doesnt like that. My old N/A ZX EFI motor wouldn't happily idle at anything less than 1000rpm, and my N/A motor with SU carbs and mild cam wouldn't take anything less than 850. So what should I set the turbo at?
Guest bastaad525
yeah I get that too after I swapped to the '75 manifold... it's not having the air bypass valve on there. I dont have to hold the gas though, even when it's freezing out side, it will start right up, and just idle REALLY low, like 500-600rpm, until it warms up.
