Oval exhaust piping
Guest jjohart
Guest jjohart
In the course of this week's install of I/C and 3 inch exhaust and downpipe, my installer mentioned that oval pipes are beneficial to flow. Can someone offer a brief explanation of why this may be so, if the gains are so nominal as to be a waste of money over standard pipes?
Thanks
John
83 280ZXT
The only real advantages of oval tubing are:
1) It can be bent in a tighter radius without crimping the tubing, and
2) It gives better ground clearance where it runs under the rear half shafts.
Unless either of those two items are needed I would stick with round - much more common, easier to work with, and less expensive.
I looked at oval because of running a 3 1/2" exhaust on the LS1 but am going to try to stick with round.
