1JZ transmission swap
Guest CR8Z
Does anyone know of a transmission that might bolt up to a 1JZ GTE and be long enough for the gearshift to be in the right location. Also the transmission has to be able to handle the engine.
The R154 will bolt up and the shifter will come up through the center if you dog leg it. Compared to everything else involved it was easy. I used the Z car top and R154 base. The G series will also bolt up but I don't know were that puts the shifter, it's also not as strong.
The R154 came with 1JZ's and 7MGTE's. The shifter will be about 2" more forward than the Z shifter. I cut the R154 shifter off at the base and welded a 3/8" thick by 1" wide by 2" long peice of steel to the stub and then welded the top of the Z shifter to that, just 2" further back. The JZ's and 7M's use a different bellhousing but the trans is the same.
  • 1 month later...
