MSA V8 Carb pump
BillZ260
so that will work well and I use a regular return line. Will the stock lines be sufficient? Anything else I need to plan for? I would like to use a fuel cell like, 16 Gallon with the GM style sending unit already in it. I am pretty clueless to this stuff, this is my first time building a hot rod, I have had several and changed stuff up but never fromt the ground up so alot of these systems are new to me.
Many of the low pressure carburettor pumps do not need a return line. Just make sure that the line size is appropriate for the HP it needs to feed. Most carbs, esp. Holleys, like volume, not pressure. You want to have a max of about 6 psi at the carb.
Tim
