240zprace Posted December 11, 2003 Share Posted December 11, 2003 i helped my buddy put in his 81turbo motor in his 73 240z, Supra IC, Bosch BOV, stock t3, boost gauge, air/fuel gauge, 370cc injectors, 2.5 exhaust into a chambered muffler. he's only getting 9-10lb of boost. now from what i think might be the problem is the muffler, because it's chambered and not flowing the exhaust air out fast and backpressure is occuring. could this be the problem???? Quote Link to comment Share on other sites More sharing options...
BayAreaZT Posted December 11, 2003 Share Posted December 11, 2003 Are you using any type of boost controller? If you are it's probably the pop off valve not allowing anything more than 10psi. Quote Link to comment Share on other sites More sharing options...
240zprace Posted December 11, 2003 Author Share Posted December 11, 2003 the stock pov is taken out and pluggrd up. using a dryer gas valve (huge) to turn up boost. the bosch bov should be a 5lb stock setting. Quote Link to comment Share on other sites More sharing options...
fl327 Posted December 12, 2003 Share Posted December 12, 2003 pull the wg line off Quote Link to comment Share on other sites More sharing options...
Guest Zcarsmakemyheadhurt Posted December 12, 2003 Share Posted December 12, 2003 Its your crazy azz boost contoller. Loose it and use a billit style valve. Your next problem should be the BOV. Can you post a pic of this power house? Quote Link to comment Share on other sites More sharing options...
