engine mounts
can any one tell me dose the motor side square or lean to one side
regards garry
It should sit level and be slightly offset to the pasenger side. If your motor is leaning, you may have the spacer plates on the wrong side...I did that too when I was a 'rookie'. The larger (thicker) spacer goes on the driver's side as is shown by the picture above.
Tim
