Ivan280zt Posted December 27, 2003 Share Posted December 27, 2003 Ok here is whats going on. while back i got killer deal on 89 300zx (z31) lsd rear end with almost brand new cv's now i know that ross c makes adaptors for 280zx cv's but i have picture of z31 adaptors and now i am wondering if anyone knows anybody that makes them as well. guys any help is more that welcome. Thanks Ivan Quote Link to comment Share on other sites More sharing options...
Guest Phil1934 Posted December 27, 2003 Share Posted December 27, 2003 I'd like to know too. I found at least 4 300 Z's with CV axles at the Pull a Part, but no 280ZXT. I've also slid under a few 280ZX 2+2's and all have had U joint axles. I've e mailed modern-motorsports the question of a 300 axle adapter a couple times, but no response. I still have the all Japanese yard on Buford Hwy. to go through, though. What size socket do i need for the stub axle nut? Quote Link to comment Share on other sites More sharing options...
fl327 Posted December 28, 2003 Share Posted December 28, 2003 I think ross was working on something for z31, not sure. s30t axles slip right in and you could use adapters for those, or use the outers from s30t and use Ross's adapter flanges. Or go full cu$tom axles and adapters. Quote Link to comment Share on other sites More sharing options...
Ivan280zt Posted December 28, 2003 Author Share Posted December 28, 2003 Phil1934 i have also emailed ross so i am waiting for response (no big hurry here) and i belive that u need something like 22mm for that nut but i am not really sure its been a while since i have taken one off. Fl327 yes i know about s130 cv's but i already have ones from z31 and they "look" much nicer and stronger on other hand did't stony use z31 cv's? and are u saying that i can go and take s130 cv's take them apart and mate the outer section to z31 cv's ? btw custom is way out of price range but would be very nice to have . Ivan Quote Link to comment Share on other sites More sharing options...
Ivan280zt Posted December 28, 2003 Author Share Posted December 28, 2003 ok i found some info and here is the picture to go with it http://www.cardomain.com/memberpage/449966 so its looks like ross did make them so we need to let him know that there is more interest in z31 cv's so that way he might start making them. Ivan Quote Link to comment Share on other sites More sharing options...
Guest HBskinheadZ Posted December 29, 2003 Share Posted December 29, 2003 Ross does make them, I am waiting for a set from him right now. You need to send him a set of companion flanges so he can weld them on. Anyone who is running these please post some info on your install, I have flipped the cages on my cv's but my understanding is they are still a tight fit. Quote Link to comment Share on other sites More sharing options...
Zsane Posted December 29, 2003 Share Posted December 29, 2003 Yeah, that's what I need, I just got an LSD and half shafts out of an 87' 300ZXT. Quote Link to comment Share on other sites More sharing options...
Ivan280zt Posted December 29, 2003 Author Share Posted December 29, 2003 HBskinheadZ can u please tell me how much do they cost and whats the turn around time? i have also went to his web page and i did't found any phone numbers i would really like to give him call if i could only find his # . Ivan Quote Link to comment Share on other sites More sharing options...
Guest HBskinheadZ Posted December 30, 2003 Share Posted December 30, 2003 They are the same price as the 280zxt ones, you should confirm that with Ross. Email him he will get back to you. Quote Link to comment Share on other sites More sharing options...
Guest 240hybrid Posted December 30, 2003 Share Posted December 30, 2003 Yeah that pic that is posted of that adapter is in my Z. Here is the funny thing...on the 300zx's, the turbo model has 4-14mm bolts and the NA version has 6-10mm bolts. Now the 280zx is the exact opposite if I'm not mistaken....the turbo model has the 6-10mm bolts. I'm going to assume that both are just about equal in strength though, but I liked the idea of larger bolts on the 300zxt CV. Ross's adapters ran me $268 and that included shipping, and took about 4-5 weeks (if I remember right) from me shipping them out, to me recieving them. Very nice items and the only problem I ran into was the length of the CV axle. Ross helped me out and is a very good source of info.. The axles a bit long for a Z. If you jack up the suspension while installing the CV to about mid swing of the control arm, installation is a bit easier. The reason for this is that with the suspension fully unloaded the distance between your adapter flange (thats welded to the companion flange) and your diff. is actually shorter. Jacking it up will give you just a bit more room to squeeze them in. I ran the car without flipping the ball and cage assembly, but I did experience a very little binding in hard cornering, and when I unbolted the axles to drop the diff out, I noticed the endcaps for the joint housings where pushed out some due to the axles being just a tad too long. The Adapter will hold the endcaps from coming completely out of the CV housing though. I ended up flipping the ball and cage assembly to get rid of the little bit of binding and for reassurance. Flipping the ball and cage assembly on the outter joint, shortens the axle about 3/8". The ball bearings are in a specific location so don't reinstall them wrong. Also the inner and outter races are located in a specific alignment, so make sure to scribe a mark to get the realigned if you disassemble them. I was able to just wrap some tape around the ball and cages, and then just flip them without the balls coming out or the races misaligning, after learning the hard way about the ball bearing and race alignment needing to be in a specific location. I think that about covers everything to do with the swap. Again, Ross's 300zx adapters work great for me and the craftsmanship is great. Chase Quote Link to comment Share on other sites More sharing options...
Ivan280zt Posted December 30, 2003 Author Share Posted December 30, 2003 Chase hey man thanks for GREAT info that will save me lots of pain lol you know i was just looking at picture of your car on cardomain last night and i was like "man i can swear that i have seen picture of this z on hybridz somwhere" silly me but you know whats cool your car is the first one on car domain under 240z and mine is first one under 260z heheheh hybridz representing . Ivan Quote Link to comment Share on other sites More sharing options...
Guest Phil1934 Posted December 30, 2003 Share Posted December 30, 2003 I did get an e mail from Ross. He makes 300 adapters for the 4 bolt axles, not 6. You have to flip the cages to shorten the axles. He is looking for feedback from people with this setup if it limits droop. Quote Link to comment Share on other sites More sharing options...
Guest 240hybrid Posted December 30, 2003 Share Posted December 30, 2003 Thanks Ivan....Ross's adapters are A1 and work great. He included the nuts/bolts necessary for installation also, which is cool as it saves me a few bucks. I'll have to email ross with some feedback as to the droop of the suspension when using the 300zx CVs. I'm almost 100% that they drop all the way down and CVs don't stop the suspension from dropping fully when jacked up from the diff. I still try to jack up one hub assembly at a time when possible just to avoid the CVs from pushing out too much on the endcaps just for peace of mind. Good luck to everyone that does this swap. Chase Quote Link to comment Share on other sites More sharing options...
Guest Phil1934 Posted December 30, 2003 Share Posted December 30, 2003 Somebody convince me I do or don't need these. I found a set of 280ZXT axles today for $200, but it seems like a lot for junkyard axles. Especially when adding in adapters. 10:1 350 with 224/234 cam, 4 2 bbls, smog heads, T5, and standard 235/60-15 tires. Only racing it will see is a couple weekends at Reynolds. Quote Link to comment Share on other sites More sharing options...
Guest 240hybrid Posted December 30, 2003 Share Posted December 30, 2003 Are you talking about ZAtlanta Phil? That is a good chunk of change if you ask me. ZAtlanta is getting a bit out of hand with their pricing lately. I would only give them about $60-$75 per CV...I mean come on, they're used CVs. I bought a couple spare 300zx CVs from there for only $50 per shaft....I had to pull one myself though. A bit of a pain to unbolt but doable without jacking the car up. Chase Quote Link to comment Share on other sites More sharing options...
Guest Phil1934 Posted December 30, 2003 Share Posted December 30, 2003 Yes, Z Atlanta. I told him I needed both axles and he told me $90 +$25 core and i told him fine, but then he delivered them to the counter and said each! I'm waiting for Ross to measure some 300 non turbo axles and see if they will work as the Pull a Part on the southside has several. I got a R200 there for $60 with m bar and axles. Quote Link to comment Share on other sites More sharing options...
dmyntti Posted December 31, 2003 Share Posted December 31, 2003 I have both the 280ZXT Cv axles and the 300ZXT axles that came with my LSD. Which one is better to use? I expect to be putting down 300 rwhp. The 300 shafts look stronger but everyone is usng the 280 shafts. Quote Link to comment Share on other sites More sharing options...
zxgts-4 Posted January 1, 2004 Share Posted January 1, 2004 Hey Don Since you have both 280zxt & 300zxt axle aren't the z31 axles too long. The reason I ask is when I pulled a Z31 R200 the tripod style CV'S were way too long to use in my 280ZX. Neil Quote Link to comment Share on other sites More sharing options...
Guest Phil1934 Posted January 1, 2004 Share Posted January 1, 2004 Ross makes a thinner adapter for the 300ZX but you still need to disassemble the CV's and flip the cages to shorten the axle some. Use the 280ZXT axles. Quote Link to comment Share on other sites More sharing options...
dmyntti Posted January 2, 2004 Share Posted January 2, 2004 Just looking at the two axles side by side the Z31 axles are longer when looking at the mounting flange. But with the 280ZXT shafts the adapter would need to be thicker because of the extension at the wheel end of the shaft. With a thinnner adapter it looks like they would be very close to the correct length which is why the adapters look so different. My question is since I can use either with an adapter is one better than the other? The 300 shaft looks stronger but that is just my opinion and I am often wrong. Quote Link to comment Share on other sites More sharing options...
