LS1 size vs LT1
Guest Your Car is Slow
LS1 is 346ci...LT1 is 350.
Iron block vs aluminum gives the LS1 a bit of a weight advantage...however overall dimensions should be nearly identical. Perhaps the coil packs on the valve covers...larger intake manifold..and accessories make it appear much larger?
