Guest tejas74260 Posted January 11, 2004 Share Posted January 11, 2004 as said in the title, these are two items i am frantically looking for. i live in texas, do you think i should go roaming salvage yards for used ones or does anyone know where i can get these? ive seen s14 lsd diffs and turbo 300zx lsd diffs on ebay, but thats about it. are both just as strong as the other? i really need a lot of help on this it would be appreciated. thanks! -mark Quote Link to comment Share on other sites More sharing options...
Guest ON3GO Posted January 11, 2004 Share Posted January 11, 2004 r200 lsd is z31 TURBO lsd... also you can always buy them new if you have the mega bucks to spend... but there hard to find also in JY's mike Quote Link to comment Share on other sites More sharing options...
Modern Motorsports Ltd Posted January 11, 2004 Share Posted January 11, 2004 Depending on your budget and intended buildup you could go with a quaife LSD setup (most preferred, then clutch then viscous for road track effectiveness/direct feedback). Quaife's can be had for R200's, a package on my site for full build that has worked great for those that have chosen it to date. As well you can use 280ZXT 6 bolt CV's or 300ZX Z31 4 bolt CV's with adaptors I offer, one bulletproof rear setup once done and all very easy install. Just options. For core parts I've always reccomended Roger at http://www.zbarn.com, mention myself when inquiring, never hurts to remind vendors it's a small world. Hope that helps. Quote Link to comment Share on other sites More sharing options...
maichor Posted January 11, 2004 Share Posted January 11, 2004 If you modify the fron mount, you can use R200s from the 240SX which are a dime a dozen here in TX. You have to check to make sure it has the little orange viscous sticker, but I have seen at least 5 in the wrecking yards on Jefferson South of Dallas. You also can do the R230 the same way and I have seen at least 4 of those in the same yards. Quote Link to comment Share on other sites More sharing options...
A. G. Olphart Posted January 11, 2004 Share Posted January 11, 2004 Maichor, what does one use for half shafts with the Viscous 240SX diffs, and in which year/model vehicles may these items be found? What ratios are the diffs? TIA Quote Link to comment Share on other sites More sharing options...
240zprace Posted January 11, 2004 Share Posted January 11, 2004 i believe all the 240sx didn't came with any lsd's.. turbo and non turbo Quote Link to comment Share on other sites More sharing options...
fl327 Posted January 12, 2004 Share Posted January 12, 2004 every turbo silvia has a vlsd, if you get a front clip and theres new rtv on the rear cover, you have 50/50 theres a cusco or other clutch lsd in there. Jspec guys really lay the rtv down.. Quote Link to comment Share on other sites More sharing options...
Cody 82 ZXT Posted January 12, 2004 Share Posted January 12, 2004 Jspec guys really lay the rtv down.. I've seen that in mag. pics. Why is that? Quote Link to comment Share on other sites More sharing options...
fl327 Posted January 12, 2004 Share Posted January 12, 2004 Ive heard some of the newer engines dont use gaskets, so they just rtv the crap out of em. Or they are too cheap to get the gasket, so they go for the rtv. For guys that put together some nice stuff, they are sloppy joe with the rtv, Ive seen diff covers with more rtv coming out the sides of the covers than sealing the cover, and its not just in a corner or a spot, its a uniform, 1/2 bead coming out the cover-they seem to only use the orange stuff too. Quote Link to comment Share on other sites More sharing options...
