Do I have my calcs correct? (BS/offset)
Broken down, I see 1/2" offset. The 8" wide rim (inside of lip to inside of lip as the industry norm for measuring a wheel width) is usually 9" from outside of lip to outside of lip. The 5" BS is based on a measurement from outside of lip, so this is why I used the 9" reference. Thus the 5" BS on this wheel is only 1/2" offset from a 4.5" centerline. Now if the 8" you are making reference to is actually outside of lip to outside of lip (which makes this a 7" wheel), then yes, the offset is 1".
I agree with blueovalz, the overall rim width of an 8" wheel is 9". Divide that by two to find the zero offset backspacing. The difference between the desired backspacing and the zero offset backspacing will be the new offset.
Offset = backspace - (width/2) = 5 - 4.5 = 0.5
Pete
