hauserdaddy Posted January 13, 2004 Share Posted January 13, 2004 I was wondering if you guys have any opinions on the quality of your wax job using a buffer/polisher or doing it by hand? I have always done it by hand but with a very busy schedule, I have less time. Would a polisher cut down on the time? I have a orbital sander that is hook and loop. They make buffers that fit onto it for polishing and waxing. Is this something you would suggest using or would you get a polisher made for polishing cars? Thanks! Quote Link to comment Share on other sites More sharing options...
evoandy Posted January 13, 2004 Share Posted January 13, 2004 I personally like waxing by hand. The only thing I would use a powered device for is polishing and buffing. Thats just me though... The sander idea might work, but it can be dangerous. With a sander you have the danger of burning the paint by working up too much friction and heat. As long as you keep it moving it shouldn't be a problem though. A buffer actually made for a car will always be the better choice. Another thing to think about is the bonnets that go on these sanders. They usually have a thick sponge under the material to protect the paint, but they also soak up waxes or whatever you use like... well... a sponge. I used an orbital buffer on my car twice and everything kept soaking into the sponge. I was halfway through the bottle of wax after waxing my car twice... If you're really that short on time, i would recommend buying an actual automotive buffer. or just use the sander hope that you're good at it... if you want more answers I suggest going to http://www.autopia-carcare.com. The guys in the detailing forums there really know what they're talking about, and the hand vs. buffer debate has been had at length there many many many times. Quote Link to comment Share on other sites More sharing options...
MikeK280z Posted January 14, 2004 Share Posted January 14, 2004 I have a sears orbital polisher. I don't believe it saves any time over doing it by hand. Additionally, While the results are good, I don't think they are any better. Keep in mind that even if you use the buffer, certain areas of the car will always have to be done by hand: heald light buckets, emblems, door handle indentation, door frames, etc. Quote Link to comment Share on other sites More sharing options...
hauserdaddy Posted January 15, 2004 Author Share Posted January 15, 2004 Thanks for the info guys. I really don't mind doing it by hand, I just wanted to hear opinions on how effective they are and if they save time or not. Quote Link to comment Share on other sites More sharing options...
