Tim240z Posted January 16, 2004 Share Posted January 16, 2004 I just bought a unit from ebay, and just received it. It is VERY VERY nice. Tolerances are close and tight but not enough to make it hang. Maching quality is great, the seller sent it very fast. Worth the $$$. http://www.goingsuperfast.com/ Tim Quote Link to comment Share on other sites More sharing options...
DavyZ Posted January 20, 2004 Share Posted January 20, 2004 Much as I hate to spend that much money, I may have to buy one I have a MOMO wheel that I can imagine getting jacked in my driveway. I also don't like the fact that they move the wheel closer to the driver. When you get the thang mounted, Tim, let me know what you think about steering wheel placement from previous position. Thanks, Davy Quote Link to comment Share on other sites More sharing options...
blueovalz Posted January 20, 2004 Share Posted January 20, 2004 I couldn't deal with the closer wheel either. I ended up shortening the column by the same amount that the wheel was moved closer. Quote Link to comment Share on other sites More sharing options...
Tim240z Posted January 20, 2004 Author Share Posted January 20, 2004 It adds 1 inch to the column. Tim Quote Link to comment Share on other sites More sharing options...
Sparky Posted January 20, 2004 Share Posted January 20, 2004 I was looking at those as well, but was a little leary about moving the wheel closer to the driver. when using a momo hub, would it be possible to section the hub by an inch? cut cut, weld weld? anywho, just trying to get some final issues with my car worked out. thanks.. -S Quote Link to comment Share on other sites More sharing options...
Tim240z Posted January 20, 2004 Author Share Posted January 20, 2004 The quick release hub takes up the space on the inside of the MOMO hub, so no you can't do that. I am likely going to shorten the steering shaft, but it's not all that bad, so I may not bother. Tim Quote Link to comment Share on other sites More sharing options...
