denny411 Posted January 30, 2004 Share Posted January 30, 2004 For some reason my truck seems to have lost oil pressure. It usually runs about 60psi at speed, and 40-45 @ idle. I made a last minute trip to advance tonight and had perfect oil pressure when I left the house, but on the way home while sitting at a traffic light the guage read 5psi. I pulled in to the fist parking lot and checked the oil (710) level. and was only down 1/2 qt. I looked under the truck and didn`t see any oil leaks. I`m gonna put a mechanical guage on it tommorrow to see what is really up. Quote Link to comment Share on other sites More sharing options...
Guest Nic-Rebel450CA Posted January 30, 2004 Share Posted January 30, 2004 When was the last time you changed the oil and filter? My truck had similar trouble, it ended up just being that the oil filter had gotten too dirty. Quote Link to comment Share on other sites More sharing options...
denny411 Posted January 30, 2004 Author Share Posted January 30, 2004 It`s probably been at least 5k or so. That would be nice, or maybe a bad sending unit. Quote Link to comment Share on other sites More sharing options...
dmyntti Posted January 30, 2004 Share Posted January 30, 2004 My truck did that when ever the rpm dropped down around idle. If I raised the RPM up the pressure would come back. When I tore it down there was a bad main bearing and I had wiped a cam lobe getting it home. I hope yours comes out better than that. Quote Link to comment Share on other sites More sharing options...
