Best way to move a front clip around?????
Guest Aguyandaredhead
Ok I have worked a deal on my RB25det clip and now I need to know the best way to move it from the trailer to garage. So how did you go about it, any good ideas would be great..
Thanks
Jeff
Well, if you need it to be mobile for a while you could build a front clip dolly. :)
Does the clip have the rotors on it? Maybe you could bolt some wheels to it, and make some levers to bolt onto the clip and walk it like a wheel barrow. How much does this thing weigh, 1000 lbs?
I am sure someone on here will have the end all best idea ever..
If you have a good engine lift/cherry picker, I would recomend backing the trailer into the garage and lifting the clip off in there.
Once it is in the air you can pull the trailer out from under it. When you get it where you want, put jackstands ner each corner.
Well we shall see, it will be delivered next Sat. I thought about the wheel barrel idea, just don't know what it might weigh.
Hey Bill I might need some muscle on that day if you are up to it..
Thanks for the ideas.
Jeff
