Guest acdatz Posted February 13, 2004 Share Posted February 13, 2004 Hi All, I just bought a 78 280z(my first) and have already had alot of my Q,s answered here, so thanks. I plan to do a stagged type of restoration on the car with my end result being a good handling, good looking V8Z. The first thing I'm going to tackle is the suspension and brakes and am leaning towards linear springs with a 1" drop. I want to know if my current tires 205/65/15 on what I believe are 280zx turbo snowflake rims, will fit under the car with the drop springs. I'm asking this because the tires look already to be sitting pretty close to the inner fender lips. Thanks Quote Link to comment Share on other sites More sharing options...
Mikelly Posted February 13, 2004 Share Posted February 13, 2004 The profile of the tire is the issue. You should be running a 50 series to insure clearance. However, My recommendation is to do a search for tire availability... You will find that tire selection in the 15 inch tire size is quickly going away in most of the Z/W/Y series tires... I'd consider an upgrade in rim size in your future plans for that reaosn alone... Even V rates tires are becoming difficult to source for 15s... Mike Quote Link to comment Share on other sites More sharing options...
Guest acdatz Posted February 19, 2004 Share Posted February 19, 2004 Thanks for the reply, but I still dont know if my current tires and wheels will fit with a set of linear drop springs. I know/plan to get a lower profile tire in the future but was hoping to get by with what I have now. Thanks Quote Link to comment Share on other sites More sharing options...
Mikelly Posted February 19, 2004 Share Posted February 19, 2004 I don't think you will be able to get by with them... They will likely rub on the inner fender lip... Mike 8) Quote Link to comment Share on other sites More sharing options...
Brad-ManQ45 Posted February 20, 2004 Share Posted February 20, 2004 205/60/15 are stock on a ZXT. 225/60/15's work w/no probs. You are OK. Quote Link to comment Share on other sites More sharing options...
Mikelly Posted February 20, 2004 Share Posted February 20, 2004 Brad, His car is a 1st Gen Zcar, not the ZX and the tires he has are 205 65 series. These tires will likely rub on an early Z if he lowers it that much... Mike 8) Quote Link to comment Share on other sites More sharing options...
Brad-ManQ45 Posted February 20, 2004 Share Posted February 20, 2004 My 75 has zx rims and 215/60/15 tires on it with TMC lowering springa and have no problems. I'd be willing to bet his springs are tired and sag. 205/65/15 and 225/60/15 ~same diameter depending on whose tire. Width definitely less w/205. Check out this link: http://zccw.org/Tech/Wheels/WheelSize.html I know he was talking an early model and not a ZX, just threw that info in - kind of wondered why he had 65 series tires... Quote Link to comment Share on other sites More sharing options...
Mikelly Posted February 20, 2004 Share Posted February 20, 2004 Well maybe it was me who had tired springs... That is what this board is good for, comparing experiences... thanks brad. My car rubbed like crazy with a set of traction master springs and 215-65-15s on the swastiker rims... Forced a tire upgrade long before I was ready... that was back in the early 90s and the car was an ealry 74 260Z. Another point you are correct about: Tire size within the same brand can be off... go mixing and matching and you see HUGE variations.. mike Quote Link to comment Share on other sites More sharing options...
Guest acdatz Posted February 20, 2004 Share Posted February 20, 2004 Thanks for the replies and the link Brad. I guess I'll have to try it and see. What's the worst that could happen? I'd have to buy new low profile tires sooner than expected. Quote Link to comment Share on other sites More sharing options...
