Question before I bid on an Ebay item..
datsunlover
Hey guys, I need to know if the SU carbs and manifold (says will fit 240/260) will bolt on to the L28 in my 75' 280z? Are there any diferences in the intake ports between carbs and FI engines? I want to bid on this, but don't ant to find out it is useless to me... BTW this is just something I want to get the car going for next year. My stock FI is all messed up, and eventually, I will swap in a 302/5 speed w/FI anyway. Anyone got concrete answers on these carbs/manifold?
As far as I know, the 240/260 carb stuff will bolt up and work on a L28E head. There are port notches and extra threads on the N42 head, but bolting up the early carb manifolds shouldn't be a problem.
I can't say for sure, so someone who does needs to pipe up.
Guest bastaad525
yeah they bolt up fine. The problem comes when people try to do the other way around and bolt EFI up to earlier non EFI heads, due to those notches Sleeper mentioned. The later EFI heads like the N42 and P90 also still had the opening on the side for using the stock mechanical fuel pump as well, covered with a blockoff plate, oddly.
