Has anyone ever....
considered converting a carb'd small block to EFI using the factory TPI retrofitted to the GEN I heads?
I saw the website LT1intake.com and thought about a hybrid system. Let me know if this would work.
I want to install the LT1 intake but use the TPI harness with ECM and all sensors.
I purchased a 350 instead of the DET, and am gathering all the necessary info and parts. I have the basic
JTR manual and read it inside out, but I need to order the one on EFI.
Any input would greatly be appreciated.
Thanks.
Rob
The '85-'89? TPI engines are MAF while the 90-92 are speed density. This is obviously easy as you can use all GM parts. The 85-86 manifolds are for old style cylinder heads, while the 87 and up are for the new style cylinder heads (but not Vortecs) Scoggin Dickey has a Vortec TPI intake.
