Tekira Posted March 3, 2004 Share Posted March 3, 2004 I am not sure what the cable goes to but its leaking. Heres a picture. I need to know what this part is so i can replace it. I think its the speedo cable. Also my speedometer doesnt work so maybe thats what it is. Thx, Josh. Quote Link to comment Share on other sites More sharing options...
JMortensen Posted March 3, 2004 Share Posted March 3, 2004 That's the speedo cable, you're right. The part under the dash is fun. One time right after I replaced my cable the drive end that goes into the side of the tranny popped out just enough to not work. You might want to pull the end off the tranny and see if that happened to you. It just unscrews with a pair of channel locks or vise grips. The end is just cylindrical, but there is a little drive pin thru it that has to hit a slot on the speedo gear to work. You'll see what I mean when you get it open. There are 2 or 3 O-rings in there that seal the speedo drive. You might be able to match up the O-rings at the local parts store, but if not you can get them from Nissan. Check that end of the speedo cable first before replacing the whole cable, you may save yourself a lot of headache. Jon Quote Link to comment Share on other sites More sharing options...
