Welding aluminized steel
CruxGNZ
I'm going to be mig welding (with gas) some aluminized steel intercooler piping and have a few concerns. Should I grind or sand down the areas to be welded prior to welding? I'm worried about contamination of the weld pool and subsequent hot cracking.
Now, I have also heard that unlike galvanized steel, aluminized steel can be sucessfully welded over. Is this true?
Any input would be great.
!M!
Mat,
It helps to just buff about 1/2 inch at the weld site of both sections. One thing to be concerned with, it that the pipe is no longer protected by the aluminizing, so it will rust on the inside. Since this will after the air filter, those rust particles will eventually make it's way to your engine.
You could send the piping in for coating when you're done to solve that issue.
