utvolman99 Posted March 17, 2004 Share Posted March 17, 2004 Here is a picture of a two speed Taurus SHO fan (Left) and a two speed Tempo fan. I am sorry but I'm not sure what year the Tempo was, it was already parted out when I found the fan at my father's shop. the Tempo fan fits my rad a lot better. The only part of the rad that will be uncovered is a small area just at the filler. Quote Link to comment Share on other sites More sharing options...
hanomon Posted March 18, 2004 Share Posted March 18, 2004 I wonder how much more air if any, that extra blade on the Tarus fan would pull (cfm)? assuming both speeds on the motors are the same. The bases of the Tempo blades seem wider so, perhaps none. I'm curious as to the blade pitch differences between the two. Quote Link to comment Share on other sites More sharing options...
utvolman99 Posted March 19, 2004 Author Share Posted March 19, 2004 I wonder how much more air if any, that extra blade on the Tarus fan would pull (cfm)? assuming both speeds on the motors are the same. The bases of the Tempo blades seem wider so, perhaps none. I'm curious as to the blade pitch differences between the two. Wow, I never really noticed that the Taurus fan had an extra blade. I wonder if that will make a big difference. The two fans are the same diameter so I could always switch blades! Quote Link to comment Share on other sites More sharing options...
Scottie-GNZ Posted March 19, 2004 Share Posted March 19, 2004 That Tempo fan is the same fan used in Escorts and is the fan being used in the GN-powered RX7 that was at SEZ. That thing moves a lot of air is definitely a candidate for a Z if it fits the radiator OK. It is 2-spd and Hi moves a lot of air. Quote Link to comment Share on other sites More sharing options...
j260z Posted April 3, 2004 Share Posted April 3, 2004 i finally found the same fan as the one in the JTR manual (seventh edition). i've been looking for that exact one because it has the two mounting flanges on the top and the way they mounted it in the manual makes it look almost stock. anyway, i found it on a 91 ford probe with the 3 liter v6. as far as the 2 speed motors go, i'm sure this one is the same as the others and only the shroud is different. the other nice thing is i got it for $12 CAD. Quote Link to comment Share on other sites More sharing options...
