bad clutch master ?
evildky
I just swapped the L28ET into my car got it running and the fuel replumbed ready for it's test run, and the clutch pedal felt soft ( I did not remove the tranny or the slave cylinder) I tried to put it in gear and it started grinding, the pedal still soft I pumped it a few times and the pedal got real hard, as in I try pressing it and the pedal starts to twist under the force, I check the fluid and it's dry? I topped it off went to the pedal still rock hard, this sound like a bad master ? I have never has anything like this happen in a master before ?
