ZX rotors and toyota calipers?
Guest ZofDoom
Guest ZofDoom
Okay so I have a set of 87 Toyota 4x4 calipers which are slightly wider then the 81 to 84 4x4 calioers. What I am planing is to use the vented rotors off a 280 ZX. Does any one see any problems with this?
Guest Drewz
you will need spacers to offset teh rotor so the caliper sits centered. The spacer is something like a half inch that goes in between the hub and rotor mating surfaces. Do a search to find the thickness of the appropriate spacer needed for your specific hub as the 280 and 240 hubs are different.
  • 4 weeks later...
No the spacing stays stock as it merely moves the rotor inborad the needed amout for alignment with the caliper once mounted.
Sweet, thanks!!!
