Guest ZofDoom Posted March 28, 2004 Share Posted March 28, 2004 Okay so I have a set of 87 Toyota 4x4 calipers which are slightly wider then the 81 to 84 4x4 calioers. What I am planing is to use the vented rotors off a 280 ZX. Does any one see any problems with this? Quote Link to comment Share on other sites More sharing options...
Guest Drewz Posted March 28, 2004 Share Posted March 28, 2004 you will need spacers to offset teh rotor so the caliper sits centered. The spacer is something like a half inch that goes in between the hub and rotor mating surfaces. Do a search to find the thickness of the appropriate spacer needed for your specific hub as the 280 and 240 hubs are different. Quote Link to comment Share on other sites More sharing options...
Guest Drewz Posted March 28, 2004 Share Posted March 28, 2004 http://www.jskinnovations.com/ventedspacers.htm Quote Link to comment Share on other sites More sharing options...
JMortensen Posted March 28, 2004 Share Posted March 28, 2004 The 280ZX has a smaller diameter rotor, so the pad will hang off the edge of the rotor. The usual setup is early 300ZX rotor with a 1/2" spacer to get the caliper to fit over the rotor correctly. Jon Quote Link to comment Share on other sites More sharing options...
Guest Drewz Posted March 28, 2004 Share Posted March 28, 2004 Oh ya. use the 300zx rotors as they are larger Quote Link to comment Share on other sites More sharing options...
j260z Posted March 29, 2004 Share Posted March 29, 2004 Ross at modern motorsports has a packaged setup for the 300zx rotor and toyota 4x4 brakes. check it out here http://www.modern-motorsports.com/catalog/product_info.php?manufacturers_id=&products_id=48 Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted April 26, 2004 Share Posted April 26, 2004 Does that conversion move out the front wheels? If so, how much? Quote Link to comment Share on other sites More sharing options...
Guest Drewz Posted April 26, 2004 Share Posted April 26, 2004 No the spacing stays stock as it merely moves the rotor inborad the needed amout for alignment with the caliper once mounted. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted April 26, 2004 Share Posted April 26, 2004 Drewz said: No the spacing stays stock as it merely moves the rotor inborad the needed amout for alignment with the caliper once mounted. Sweet, thanks!!! Quote Link to comment Share on other sites More sharing options...
Guest Drewz Posted April 26, 2004 Share Posted April 26, 2004 Quote Link to comment Share on other sites More sharing options...
