80LS1T Posted April 13, 2004 Share Posted April 13, 2004 I would like to paint all the black trim pieces on my 280ZX due to them being faded. Im just not sure about how to paint them so that the paint holds up to daily driving. I know once my car is painted that I will probably wash it 2-3 times per week. I think if I spray paint them it will just get washed off or wear off extremly quick? So how do I need to go about this? Is there a specail product that I can use for black trim to make it black again? Thanks! Guy Quote Link to comment Share on other sites More sharing options...
80LS1T Posted April 13, 2004 Author Share Posted April 13, 2004 What's "SEM"? So I dont need to primer them or anything? Thanks RacerX! Guy Quote Link to comment Share on other sites More sharing options...
Wagz Posted April 13, 2004 Share Posted April 13, 2004 SEM is a brand of higher quality paint products/chemicals. The only place I've found SEM products is at a local automotive paint supply house. If you clean/scuff the parts properly, you shouldn't need to prime to get the trim color to adhere well. I'm going to be doing this on some trim pieces on my 300ZX this week too. Quote Link to comment Share on other sites More sharing options...
jonzer12 Posted April 13, 2004 Share Posted April 13, 2004 Use adhesion promotor, I had posted picks of my painted plastic interior last year sometime. Sand each piece, clean it, apply adhesion promotor, paint then put a couple coats of cheap spray can clear coat. It will hold up great. Quote Link to comment Share on other sites More sharing options...
Guest Phil1934 Posted April 13, 2004 Share Posted April 13, 2004 Check Lowe's. They have a spray paint called Krylon for Plastic. I think it was Krylon. Anyways that's all you need. Quote Link to comment Share on other sites More sharing options...
Guest steveo Posted April 13, 2004 Share Posted April 13, 2004 have you tried any cleaning products yet? i think its McGuires that has "back to black" which is suppose to be awesome mothers and others make similar products. I've heard wonders about them, but never tried it myself. * just did a quick search on the mothers site http://www.mothers.com/products/ click on special then scroll down. Back to black is there* Quote Link to comment Share on other sites More sharing options...
80LS1T Posted April 13, 2004 Author Share Posted April 13, 2004 I think I'll just try the gray scotch brit pads and teh SEM trim paint. I see how that holds up. Thanks guys! Guy Quote Link to comment Share on other sites More sharing options...
GAZRNR Posted April 15, 2004 Share Posted April 15, 2004 Sherwin-Williams is selling a krylon spray paint for plastic. It works but comes in gloss colors only. Give it a try. Quote Link to comment Share on other sites More sharing options...
smokeshow Posted April 20, 2004 Share Posted April 20, 2004 Wash the parts well with soap and water - rinse well and dry. Then lightly scuff them plastic parts with a gray scotchbrite pad or something equivalent and wipe clean. Then you can spray them with SEM trim black (spray can)or something equivalent. Hope this helps. RacerX This is very good advise. SEM works great, I've used it countless times. Quote Link to comment Share on other sites More sharing options...
