Muskrat Posted April 22, 2004 Share Posted April 22, 2004 I've seen several people either in the process or have already completed a supercharger installation on an L-series engine. However, the only one that I've heard of that is complete and running is also using megasquirt for fuel management. I'm curious to know if I could run an intercooled supercharger setup on the stock 82 turbo EFI that I have. I'm down a turbo and using a flattop block, so I think this would be an awesome alternative for me. I can fabricate the mounts, piping, and air box for this setup, I just need to know if I can run my stock turbo EFI. Quote Link to comment Share on other sites More sharing options...
Muskrat Posted April 22, 2004 Author Share Posted April 22, 2004 Would a Z31 ecu conversion be a better choice for this? Quote Link to comment Share on other sites More sharing options...
SleeperZ Posted April 22, 2004 Share Posted April 22, 2004 I would think either ECU will work fine for the supercharger setup. Quote Link to comment Share on other sites More sharing options...
280zedx Posted April 24, 2004 Share Posted April 24, 2004 A forced induction engine is just that. So yuor stock turbo setup should work just the same assuming you keep your pulley ratio in the same psi paramater. If you go higher boost you can modify just like a turbo, ie. intercooler, bigger injectors, a Z31 ECU setup etc. It's the creative fabricating that's required to make it fly. Mike Quote Link to comment Share on other sites More sharing options...
