1/4 mile time with stock l28et swap
Guest zmepro
Guest bastaad525
You mean stock boost as well? Stock boost stock everything in a 240 is good for high 14's and a 0-60 of about 6.5 seconds. Turn the boost up to 9-10psi and you'll be around high 13's and 0-60 in about 5.5-6 seconds.
I'm running about as close to stock as they come. Only changes to my car are the obligatory K&N filter, an MSD ignition and fuel pump, a performance clutch and lightened flywheel, and a BOV (consider this mandatory) running 10psi with a cheap DIY manual boost controller, I put down 200hp, and I have weighed my car at 2320lbs with my tools, jack, spare, and about 1/2 tank of fuel in it. Power to weight dictates about a 13.6 if I drive it well. Oh and I'm running a VERY restrictive exhaust... certainly not helping anything.
