18PSI?
240hoke
Ok,
Im getting really bad gas milage so im getting my car back on the dyno to do some more tuning. I figured while i was there might as well get my boost controller setup, and raise the boost of course.
My 3bar MAPP sensor should be coming in this week, soo..... I will be able to raise my boost above 15psi.
I was thinking about running 16-18PSI. How much is too much? Right now im running 370cc SVO injectors and I would like to max those out. Ive heard they supply enough fuel for ~320hp at 80% duty cycle.
I am still running the stock internals.
Whatddya think 18PSI????? :twisted::twisted::twisted:
-Austin
Guest bastaad525
what cars do those injectors come from anyways? Hopefully not only from that crappy SVO turbo four banger mustang?? Those are kinda rare..... arent they??
Well i got the mapp sensor today, i gotta give it to the SDS guys they are fast! I ordered it yesterday when i got home from school ~3:00 and it was here when i got home today. woohooo, aight sounds like 18 psi is good then, well see what the air fuel ratio does on the dyno nere in a week or so!
On the injectors, i bought mine off ebay there were plenty when i looked. You just kinda take a gamble on if they are good. Mine were fine. i bought 4 used ones and 2 that had been professionally redone. Total was less then 100 bucks.
-Austin
the 87-87 T-bird Turbocoupe also came with the bigger afm and injectors, so not as rare as you might think, problem is you only get 4 in a set
