Is it the AFM?
Ok long storie short I did a full tune-up car seems 2 run fine but it blows black smoke when idling and allot more when i rev it up. Is it the AFM i think thats all it could be, ive read some posts about adjusting it(AFM) but be for i try that i wanna see if there might be something i missed?
thanks: Matt
wheni pulled the plugs after running it for a while the were all the same across all cylinders, could all the injectors be bad equaly? thats hard 2 beleve. im thinking its more AFM if im going 2 take off the injectors im going 2 get new ones thanks for your post CozyZcole
Sounds like the AFM could be acting up... or maybe the TVS.. if its not reading at idle, the ecu might be getting confused and dumping in too much fuel. You could try disconecting it and starting the car; That should throw the computer in to a 'failsafe' or limp mode, where it runs on a pre-programed code instead of using the sensors to run the engine. It'll only let you rev to 2500 or so, but if it runs better (no more smoke) then it's probly the TVS... You'll probly be confused right now on 'what the heck is a TVS?' Throttle Valve Switch. Alot of ppl just call it a TPS (throttle position sensor) but it's not. It's just two switches in side.
You should check the Thermotime temp switch too. If it isn't working, the computer thinks the engine is cold and runs the mixture rich.
It's an expensive sucker at $60, but important. It's high on my list of stuff, right after the headlights.
