wigenOut-S30 Posted May 20, 2004 Share Posted May 20, 2004 Well I got a 3.70 LSD(at an awsome price I might add thanks Pallnet ) and I need to know what Diff fluid weight you guys are running and what are good brands out there.. I also heard you have to get a LSD additive to add in as well.. So what are you LSD guys using for fluid and LSD additives? Thanks in advance.. .. I am putting it in this friday night and I cannot wait to actually get traction!!!.. Quote Link to comment Share on other sites More sharing options...
JMortensen Posted May 20, 2004 Share Posted May 20, 2004 I've been running straight SWEPCO 201, works great. If you don't want to pay through the nose for gear oil, you can use standard 80-90 and any posi additive (contrary to the rumors they are all basically the same). Jon Quote Link to comment Share on other sites More sharing options...
QWKDTSN Posted May 20, 2004 Share Posted May 20, 2004 I just filled up my new LSD with Mobil 1 synthetic 75-90 weight oil (I used about 1.70 quarts or so with the finned cover... as my research showed a standard R200 to use 1.5) and a tube of the posi additive that Kragen had. Don't remember the brand but I'm sure pretty much whatever the local place has is fine. Good luck with the install, mine has spanned about four days so far as I decided to spare the fins on the cover (couldn't see a way to make the suspension brace fit, even if I removed them!) so I've been working on fabbing up a brace. I also spent quite a bit of time dreaming up and fabbing a limiter to keep my front diff mount from breaking while I was at it. I can't wait for the traction as well, as well as lower revs as I've been running a 3.90.. Quote Link to comment Share on other sites More sharing options...
JMortensen Posted May 20, 2004 Share Posted May 20, 2004 Nion, have you seen Jeromio's site??? http://240z.jeromio.com/diffmount.html Quote Link to comment Share on other sites More sharing options...
QWKDTSN Posted May 20, 2004 Share Posted May 20, 2004 Yup, I have seen his solution.... Very well-thought out and well-executed! My idea was inspired by the one shown on http://www.kaynor.net/v8-240z/index.html (not the LSD brace... the front mount limiter).. basically I welded several bolts to the front of the diff mount and bolted on a piece of angle iron that goes down and underneath the crossmember with a gap of about 3/8". The rubber mount can isolate vibrations but if it gets torqued too much it will hit the limiter and stop, so it can't stretch enough to break. Quote Link to comment Share on other sites More sharing options...
Drax240z Posted May 20, 2004 Share Posted May 20, 2004 I'd recommend redline 75w-90 oil... it allready has the additive in it if I am not mistaken. (read the label, but I am 99% sure it has it) You'll love that diff! (I don't have one, but one of the Z's at the shop does, it's great) Quote Link to comment Share on other sites More sharing options...
QWKDTSN Posted May 20, 2004 Share Posted May 20, 2004 I just want to say, I love my diff!! Haha! Got it all buttoned up this morning and the freakin' thing is awesome. First thing I did was take it into the parking lot next door to my house and do the figure 8's as is recommended, to get the lube into the clutches so they won't burn up. At first I heard some squeakings, clunkings, and various noises coming from 'back there' but after about 5 figure 8s it quieted down. I did around 20 total and then went for a drive.. First time I punched it taking a corner from a stop sign I almost lost it because of how fast the rear end snapped around! U-turns sure are fun now! Oh, yeah... I got pulled over already Cop just gave me a fix-it ticket for no front license plate because I admitted to doing wrong Thanks! Anyway, I'm amazed at how well the car grips now going through sweeping corners. It's just out of this world! I can keep giving it more gas and it just digs in harder and keeps pulling through! Confidence inspiring to say the least. I'm about to upload a few photos of the install, if anyone's interested. Quote Link to comment Share on other sites More sharing options...
Guest zline Posted May 29, 2004 Share Posted May 29, 2004 Well this is the gear oil i recommend to all customer/friends and everyone else for that matter NEO synthetic 75W-90HD specs: Viscosity Index 165 (ASTM D-2270) Flash Point 405degF (ASTM D-92) Pour Point -50degF (ASTM D-97) Film Strength 3-6x petroleum GL-2 through GL-5 rated for use in synchromesh transmissions and differential pretty cheap too 44 dollars a gallon! Also for motor oil (i know i know OT) I like the NEO 20W/50 but i live in CA so cold weather is nonexistant(below 40*F) they have a 15W/50 that is nice for cold weather Quote Link to comment Share on other sites More sharing options...
Guest the_dj Posted July 21, 2004 Share Posted July 21, 2004 I'm putting Royal Purple MaxGear 75W90 in mine this weekend. O'Reilly's near my house sells it. It does already have the LSD additive in it. http://www.royalpurple.com/prodsa/mgeara.html Quote Link to comment Share on other sites More sharing options...
