Guest polarity Posted November 21, 2002 Share Posted November 21, 2002 well after a little research, seems the major two issues are 'cool factor' and exhaust routing. anyone care to say how hard a fuel cell is to mount in and if it is worth the time/money/effort you put into it? Billy Quote Link to comment Share on other sites More sharing options...
74_5.0L_Z Posted November 21, 2002 Share Posted November 21, 2002 I used a fuel cell for two reasons. First, the stock tank had sat for 12 years with fuel in it (what a mess). Second, by switching to a cell, I made room for a dual exhaust. I cut out the spare tire well, and centered a 16 gallon cell between the rear frame rails. This gave me room to run a Flowmaster on either side. Also the cell is invisible from the rear because it is level with the bottom of the rear valance. If you get a fuel cell, get an aluminum one or better yet get an ATL ($$$). The polyeurathane ones deform. Quote Link to comment Share on other sites More sharing options...
Pop N Wood Posted November 21, 2002 Share Posted November 21, 2002 I want one in my Z because I want to run dual exhaust out both rear corners. The fuel cells just seem more compact than trying to adapt a bizarre shaped tank designed for another car. If you look through the Summit catalog you will see you can get a tank of almost any size you want. For my Z the nice, rectangular shapes should provide a good fit. Also there is something to be said for starting with a brand new, unused, unrusted, fumeless tank instead of draining and trying to cut up an old tank full of fumes. I am sure other guys will chime in with a the safety advantages. I know you can get them foam filled also. Quote Link to comment Share on other sites More sharing options...
deMideon Posted November 21, 2002 Share Posted November 21, 2002 In addition to the dual exhaust, I will be running about 450hp so I wanted to make sure I had the fuel line out of the tank large enough, and I wanted to set the tank as far forward and a little to the passenger side for better weight distribution! Quote Link to comment Share on other sites More sharing options...
Tim240z Posted November 21, 2002 Share Posted November 21, 2002 If you get a fuel cell, get an aluminum one or better yet get an ATL ($$$). The polyeurathane ones deform. I disagree. If vented adequately, the 'plastic' cells last a long time. I know of MANY cells that have been used in race cars, in hot environments, for in excess of 10 years with no sag.Tim Quote Link to comment Share on other sites More sharing options...
Guest polarity Posted November 22, 2002 Share Posted November 22, 2002 I have seem some posts in the past about fuel cells, can anyone tell me why you would chose this over using a regular gas tank? are there any benifits, if you have time. how does it work, why do you have 'filling station' in your garage? Billy Quote Link to comment Share on other sites More sharing options...
