Fuel Mix affected by exhaust change?
Guest ckmoss01
Guest ckmoss01
Good Morning Guys:
I recently had my exhaust redone, resulting in combining the two 2 1/4 inch pipes with turbo-stle mufflers into one single turbo-style muffler w/ 2 1/4 outlet.
It almost seems as though the car is getting too much fuel - as I can get some nasty backfires and throttle stutters which I didn't previously recognize.
This occurs mostly after a stop light and in 1st and 2nd gear.
I wonder if your collective wisdom might provide some guidance.
Thanks so much for the input.
CMOSS
the efficiency of the cylinders exhaust scavaging and the rpm range where it occures is effected in a MAJOR way by the headers and exhaust design, changing the exhaust restriction levels almost always results in a MANDATORY total retune/rejet or remap of the intake to match the new engine characteristics
read this
http://www.uucmotorwerks.com/html_product/sue462/backpressuretorquemyth.htm
