Miles Posted September 13, 2002 Share Posted September 13, 2002 Can anyone recommend a manufacture and part number for a bottom radiator hose to fit between the SBC water pump and the Griffin bottom outlet? My 19" x 22" Griffin has the bottom outlet tube angled slightly up so it looks like the hose is going to have to make some compound bends to line up with the outlet tube. Thanks Miles Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted November 20, 2002 Share Posted November 20, 2002 I need an answer too about the lower radiator hose for a Griffin. The unanswered post by Miles is what I found in the search function, I have the 24X19 Griffin with the 1 3/4 inch lower out let and with a long neck SBC waterpump running a belt driven FlexoLite fan. Griffin recomends the universal flex hose that I am not too keen on. I found a 73 Monte Carlo 350 SBC upper hose works on the top. Would a 1971 Nova 350 SBC lower work? Any solutions would be apreciated. Any 20 inch wide shrouds that I could make fit for the for the Griffin and Flexolite fan? Quote Link to comment Share on other sites More sharing options...
jt1 Posted November 20, 2002 Share Posted November 20, 2002 I'm running the 24 x 19 Griffin w/ a SBC with an Edelbrock aluminum water pump w/1 3/4 inlet, JTR position, in a 73 240Z. My Griffin has the odd looking angled lower outlet, 1 3/4" Dia. A friend that runs a NAPA store let me root thru his hoses for about half a day & take several home to try, & bring back what didn't work. I used a NAPA # 8948. It has a crook in the last 6 or so inches that you have to cut off, then it works fine. I have no idea what it fits. It DOES NOT have a "spring" in it to keep the hose from collapsing at high RPM. You need the spring in the lower hose, so I used the one out of the universal flex hose I used to run. If you don't have a spring, you may have to buy another hose to get the spring. I don't know of a source for the spring separately, maybe someone else does. Hope this helps. John Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted November 20, 2002 Share Posted November 20, 2002 JT 1 Thanx... I called Napa and was told they could not identify the application for lower radiator hose #8948 ($15.29) I kept the spring from the hose on the donar car. They ordered the hose for me. Just another nickel and dime expense but I want that custom molded look rather than a flex hose (the cost of vanity or might as well do it now) Quote Link to comment Share on other sites More sharing options...
jt1 Posted November 21, 2002 Share Posted November 21, 2002 I like the look of the molded hose a lot better too. The molded hoses are a lot better quality than the flex ones anyway; flex hoses are intended to be a stopgap repair. They start cracking pretty soon. I can email a pic of mine if you want it. John Quote Link to comment Share on other sites More sharing options...
PaulR Posted November 23, 2002 Share Posted November 23, 2002 On this site: Brians Garage The author states "I ended up using a Gates/ECR p/n 20608 for the lower hose and a Gates/ECR p/n 7368 for the top hose. I had to cut a little off of each of these hoses. Note that the 20608 should work for a Chevy in the "Set-Back" position also." Paul Quote Link to comment Share on other sites More sharing options...
DavyZ Posted November 23, 2002 Share Posted November 23, 2002 Thanks for bringing that info up, Paul. Brainstorming is great with a group like this Love your Z BTW. Davy Quote Link to comment Share on other sites More sharing options...
PaulR Posted November 23, 2002 Share Posted November 23, 2002 Yeah, it kinda weird sometimes... I was planning to replace the lower hose today and had already done the research and found the info from Brian's site. Then, I just saw this post as I was having my morning coffee before going out to my shop (the building in the background of my sig)! BTW, I did a quick look on napaonline and their p/n for the Gates 20608 is 7369 and it does include the inner coil. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted November 24, 2002 Share Posted November 24, 2002 I have the referenced #8948 lower "napa" hose and it appears to fit with trimming. Some time today I will que up the courage to circumsize a $15.29 hose.(Re-edit)The circumsicion was successful. .... and requires a coiled inner spring to keep the hose stiff and prevent collapsing.....maybe a substitute for Viagra,,,Ouch !!!!!! Quote Link to comment Share on other sites More sharing options...
PaulR Posted November 27, 2002 Share Posted November 27, 2002 Well, here's an update: I tried the Napa 7369 hose and didn't like the fit... so I had the local Napa store order the 8948 hose. I just installed it and it was a much better fit. So, the bottom line is use the Napa 8948 lower hose with a Giffin radiator and a SBC in the JTR position. Quote Link to comment Share on other sites More sharing options...
