Not a Z question...but...66 Chevy truck not starting
My neighbour has a 66 Chevy truck with a 283V8.
I just gave it a complete tune up...plugs, points, condensor, coil, filters, timing etc etc...but an ongoing problem has been starting it:
When turning the key to the "start" position, nothing happens...absolutely nothing...no clicking, whining or anything from the starter (which is fairly new). The battery is also brand new.
But...if I hook up the quick charger to it, it fires right up and purrs like a kitten (thanks to my wonderful tuning :D:roll: )
I checked all the connections and cleaned (sand paper &/or wire brush), sprayed all the connections with electrical cleaner....all the usual stuff......
I just don't understand...if it was the ignition switch, it wouldn't fire at all, even with the booster, right?
When it is running the alternator is charging at ~14 volts (at about 1500RPM).
What could it be?
Tim
When your connecting the quick charger are you connecting ground to the battery or body ground? Check the battery independently, you may have a defective battery. I've had it happen to me to where i get the voltage but the cranking amps were not there. Turns out to be defective cell.
Kinda sounds like the problem I had with my OPTIMA battery. It sat over winter with out being used. Then this spring when I went to fire it up it wouldnt turn over the engine. I checked the battery and it was low on voltage so I trickle charged (this is the only way to charge an OPTIMA, just so you know). Put it back on the car, same thing. I took it back to get a new one and it wouldnt pass the load test. I ended up getting screwed big time by AUTO ZONE because "they couldnt find me in there records saying that I did buy the battery from them" :evil: (I'm still very PO'd about that one!!!!!) After I put in a new battery the problem was gone.
Guy
Guest 305240
Tim,
Would you by chance have used some of the spray stuff that prevents corrosion on the battery posts and terminals? I've seen this done to a few cars and they wouldn't start. On one particular car, I took the battery clamps off, wiped them and the battery posts off, cleaned them with carb cleaner, put them back on, tightened them up. The car started.
What makes me think this, is what you said. It will start with a charger attached. Common denomater is the clamping system. Hope this helps.
You can isolate the ign. switch by shorting the poles on the starter solenoid (with the ign. set to On of course).
But my guess is that it's the solenoid or the starter. The fact that the starter is "new" is immaterial. Especially if it's a reman from a chain store. I've gotten so many defective parts from these places that I will only ever buy from those chain stores if the repair is critically time sensitive and the "regular" parts counter is closed.
can you test the starter outside the truck? if so do that.
im sure its the starter' date=' nothing else could cause this.
mike[/quote']
What he said, maybe the starter is requiring more amperage than normal to crank.
While I agree that its worth looking at, I find it wierd that the starter makes absolutely no noise when not hooked to the booster....I would have thought that it would at a minimum click, or tick or something.....I'm leaning to the ignition switch a bit more, but I will have to wait for my neighbor to get home (he works wierd hours--fireman)
Guest 305240
tear into the solinoid. check the main terminal inside it. often times just pushing it in and turning it 1/2 a turn will fix it. also check the disc inside of it. could be with the charger attached, it gives it just enough juice to make contact.
Try a remote starter, you know the ones professionals use when they want to bump the motor or use a screwdriver. If it starts on the same battery without the quick charger, then it probably is the ignition switch.
The starter will engage when shorting the 2 terminals to the main power terminal. That's what is making me lean towards the ignition switch. It has a master plug going to it, so it will be very easy to disconnect the switch and jumper the terminals in the plug as a test.....
Tim
Tim,
Sounds like the ignition switch to me since you are basically using another switch with the remote starter. The remote starter requires the key to be in the on position, correct? Sounds like the start position circuit isn't making contact in the 38 year old switch.
Joe
