spewing gas all over - are my floats stuck?
zliminator
After the fuel pump runs for about 10 seconds, fuel starts pouring into the 2ndaries down the 2 venturies? and up the tube which points straight up. Is this a sign that my float is stuck open? I have a Holley 750dp. Its been a while since I adjusted the floats but I didn't do anything to upset it except take it off and spray it with carb cleaner. It probably needs a rebuild too.
zliminator
Yup, stuck float. Try rapping the float bowls with the handle of a screwdriver to get them to break loose. This is a fairly common problem but if it continues you may need to rebuild the carb and replace the needle and seat. Also check for a heavy float.
