z-REX Posted July 8, 2004 Share Posted July 8, 2004 hey guys... my 240 turbo has been running rich down low since i bought it, so i picked up a boost- referenced msd adjustable fpr, and went the ghetto lowes pressure gauge route. i hooked up the gauge first and was shocked to find the idle pressure to be right around 38-40. stumped. i know it's running rich... it bogs noticably off the line unless i launch at 3500 plus, and i've seen the plugs... before i changed them my last set was jet black. so why in god's name am i running rich???? if i had hair i'd be yanking at it right now. Quote Link to comment Share on other sites More sharing options...
z-ya Posted July 9, 2004 Share Posted July 9, 2004 What is your setup? Pete Quote Link to comment Share on other sites More sharing options...
z-REX Posted July 9, 2004 Author Share Posted July 9, 2004 pretty much stock turbo engine.... 77 ecu, barely even started to upgrade. Quote Link to comment Share on other sites More sharing options...
z-ya Posted July 9, 2004 Share Posted July 9, 2004 Sounds to me like a sensor problem, like water temp or the air flow meter. Does it run rich all the time, regardless of engine temperature? Pete Quote Link to comment Share on other sites More sharing options...
z-REX Posted July 9, 2004 Author Share Posted July 9, 2004 yeah, it's all the time. i know some adjustments were made on the afm before i got it, basically the p/o's way of getting the engine to not lean out in spool range. damned if i know how to re-adjust it, but now that i'll have the fpr to add fuel when i need it i shouldn't need the afm tweaked like that. seems like the logical solution... now what do i do about it? Quote Link to comment Share on other sites More sharing options...
z-ya Posted July 9, 2004 Share Posted July 9, 2004 If everything is stock (injectors, etc), then see if you can find an AFM that hasn't been mucked with. You should run the stock FPR too. Get it running good in stock form first, then start modifying things. Quote Link to comment Share on other sites More sharing options...
monster626 Posted July 10, 2004 Share Posted July 10, 2004 just a thought ......if you are using the stock 77 comp make sure you are using the n/a injectors or you will always run rich. if thats not the case and you are using them sorry i didn't help Quote Link to comment Share on other sites More sharing options...
Z-Gad Posted July 10, 2004 Share Posted July 10, 2004 Fuel pressure for the stock injectors should be 36 psi with the vacuum line disconnected (pinched, or plugged). It sounds like you have too much fuel pressure still... Quote Link to comment Share on other sites More sharing options...
z-REX Posted July 10, 2004 Author Share Posted July 10, 2004 yeah, a friend told me the same thing... he's the prez of my z-club and has built a few of these himself. my numbers must have been off. even though he said he ran more like 28 at idle and lemme tell ya his car flew so, i guess i bought the regulator for a reason after all... thanks guys for all the help! Quote Link to comment Share on other sites More sharing options...
