powershift Posted July 9, 2004 Share Posted July 9, 2004 hi, im planning on running a chevy 327 in a soon to be mine, 240z, using the jtr motormounts will a holley 144 supercharger fit with the stock hood, with the carb and airfilter, and if i need a cowl hood, how big. thanx alot. -Vin Quote Link to comment Share on other sites More sharing options...
Dan Juday Posted July 9, 2004 Share Posted July 9, 2004 Pretty sure you're going to need a cowl. Look for posts from COZY-Z-COLE. That's Larry. He's the only one I know of on this site running a sbc with that blower on a Z. He uses a cowl hood. Quote Link to comment Share on other sites More sharing options...
powershift Posted July 10, 2004 Author Share Posted July 10, 2004 thanx, but i cant really find anything on him talking about a S/C sbc, you wouldnt happen to know what size the cowl ,and the blower was (im running a single carbed 144, smallest made) Quote Link to comment Share on other sites More sharing options...
Guest Phil1934 Posted July 10, 2004 Share Posted July 10, 2004 Hot Rod mag did the same swap 20 years ago and had to run a cowl hood. Looked the same height as stock Chevy offerings so I'd say 2". Quote Link to comment Share on other sites More sharing options...
quicker240 Posted July 10, 2004 Share Posted July 10, 2004 I had planned to use that blower a while back and doing some measurements,found that the whole setup was only 1 1/2 inches higher than a standard carb/intake.The blower intake sits very low in the intake valley.You may have to be a little creative with the air filter,either using a remote or a low profile of some kind,but I think you could fit it under a stock hood without too much trouble,if thats your goal.A centrifigal may give you a few more options though.Good luck with it!! Quote Link to comment Share on other sites More sharing options...
Guest Phil1934 Posted July 10, 2004 Share Posted July 10, 2004 I had to keep a 144 low on a car I'm building so put on the Holley Projection which is about an inch lower. It also had a filter adapter I chucked and just hammer formed a filter housing neck to save another 1/2". If you need specifics I can go measure against a Holley, but I think you'll need th ehood or weld a bubble on the stocker. I picked up some from a street rod supplier as I still missed my mark by 2". Quote Link to comment Share on other sites More sharing options...
powershift Posted July 10, 2004 Author Share Posted July 10, 2004 this is good news thanx a bunch, now i dont have to build a new motor. ( by the time i got my 327 to be as fast as it was blown N/A it would be a whole nother motor!) this site just saved me a 4000$ headache. Quote Link to comment Share on other sites More sharing options...
