Guest Loose_Screws Posted July 10, 2004 Share Posted July 10, 2004 Should any check valves be installed on the vacuum lines going to the brake booster and heater controls after turbocharging a stock '77 280Z? I have actually driven the car a good bit without adding any check valves. Would this damage the brake booster or dash control panel for the heater/ac controls? Quote Link to comment Share on other sites More sharing options...
cygnusx1 Posted July 10, 2004 Share Posted July 10, 2004 Hey glad to see this topic here. I thought about this also when doing my swap and I did decide to put in check valves on all the old vacuum lines. Why not, it cant hurt. Dave Quote Link to comment Share on other sites More sharing options...
TimZ Posted July 10, 2004 Share Posted July 10, 2004 Yes you should definitely have check valves for both the brake booster and the vacuum accessories. The stock check valves will suffice. Quote Link to comment Share on other sites More sharing options...
Guest Loose_Screws Posted July 10, 2004 Share Posted July 10, 2004 Yes you should definitely have check valves for both the brake booster and the vacuum accessories. The stock check valves will suffice. The stock ones will work even if the car came stock without a turbo? Thanks for the replies! Quote Link to comment Share on other sites More sharing options...
Tony D Posted July 11, 2004 Share Posted July 11, 2004 I used the check valves from the donor car (83ZXT) on the vacuum system, and the original brake booster check valve from the 260. I have been running the stock brake booster check valve in my turbo 240 since 87 with no problems. But yeah, I grabbed the turbo check valves (which looked the same as the stock 260Z check valves) and used them on the vacuum reservoir for the heater controls. Quote Link to comment Share on other sites More sharing options...
TimZ Posted July 11, 2004 Share Posted July 11, 2004 The stock ones will work even if the car came stock without a turbo? Yep - the stock ones will work just fine. Quote Link to comment Share on other sites More sharing options...
