Guest 007fastZ Posted July 18, 2004 Share Posted July 18, 2004 i'm doing the sbc swap in my 280zx and i've been putting all my pieces together and was trying to figure out what kind of oil pan to run. I have a short block with eagle forged crank and rods and je pistons. I'm ordering my heads, cam, lifters, and roller rockers next week. I'm building the motor to produce power at a higher rpm so its getting a solid roller cam, and will have around 585/585 lift. i want to use a 7 quart pan so i can run a high volume pump. I'm not quite sure if i will have enough clearance. I have a 280zx 2+2 lowered about an inch an a half. I plan on making around 500hp. Any help? Thanks Quote Link to comment Share on other sites More sharing options...
Zfreak Posted July 19, 2004 Share Posted July 19, 2004 I m using a 7 qt. Hamburger oil pan. Its shorter than stock and has all the good stuff for controlling the oil. Its a road race style. Check my webb page for a picture or two. Quote Link to comment Share on other sites More sharing options...
spdsk8r Posted July 19, 2004 Share Posted July 19, 2004 I'm using a 7qt. Moroso pan in my ZX. I also am running slightly lowered suspension. The pan sits slightly lower than a stock pan. With caution, it should work all right (no speed bumps). You should be able to see it in the pic of the trans mount on my page below. Quote Link to comment Share on other sites More sharing options...
Guest 007fastZ Posted July 20, 2004 Share Posted July 20, 2004 Thanks for the help guys. Spds8er what motors mounts are you using Quote Link to comment Share on other sites More sharing options...
spdsk8r Posted July 21, 2004 Share Posted July 21, 2004 The motor mounts are for a late 60's, early 70's Chevy pickup. The spacers are homemade. Quote Link to comment Share on other sites More sharing options...
Guest the_dj Posted July 22, 2004 Share Posted July 22, 2004 You can't run a high volume pump with a stock pan? Quote Link to comment Share on other sites More sharing options...
Heavy Z Posted July 22, 2004 Share Posted July 22, 2004 Sure you can. Quote Link to comment Share on other sites More sharing options...
Guest the_dj Posted July 22, 2004 Share Posted July 22, 2004 How about a high volume pump and feeding two turbos? I believe if you just make sure the oil doesn't run low there wouldn't be any problem at all. Quote Link to comment Share on other sites More sharing options...
Heavy Z Posted July 22, 2004 Share Posted July 22, 2004 How about a high volume pump and feeding two turbos? Yes, a bigger pan would be an excellent cautionary step. Quote Link to comment Share on other sites More sharing options...
danc Posted July 25, 2004 Share Posted July 25, 2004 I'm using MSA mounts on my 83 ZX with a GM Performance parts Fastburn 385 and had to massage the bottom of the pan of both sides to clear the R&P. Other than that works great. There is a parts list on GM performace parts for that motor and sure you get the part #.. Quote Link to comment Share on other sites More sharing options...
Guest 007fastZ Posted July 26, 2004 Share Posted July 26, 2004 i've heard if you are going to be running high revolutions that you can run the pump dry with a high volume pump and a 5 or 6 quart pan Quote Link to comment Share on other sites More sharing options...
