80LS1T Posted August 2, 2004 Share Posted August 2, 2004 I work at a Dodge dealer and we just installed a stage 2 kit on a SRT-4 last week. Now part of that kit is a I/C "cooler" I guess you would call it? What it does is spray washer fluid on the I/C when you press a button in the car. Now just how effective is something like this? Guy Quote Link to comment Share on other sites More sharing options...
Guest ON3GO Posted August 2, 2004 Share Posted August 2, 2004 if its a simple window washer pump then not very... the STi has this also.... Quote Link to comment Share on other sites More sharing options...
slownrusty Posted August 2, 2004 Share Posted August 2, 2004 On the STi it works well as that IC is top mount and heat soak is the number one complaint from WRXSTi owners. In Japan the Evos have a factory water spray option. Personally I would convert that kit to a water injection kit! Yasin Quote Link to comment Share on other sites More sharing options...
wigenOut-S30 Posted August 2, 2004 Share Posted August 2, 2004 I hear it can help out apretty good bit. but even better would be to convert it over to spraying Co2. This will make a huge difference in the cooling effect of the IC. Quote Link to comment Share on other sites More sharing options...
80LS1T Posted August 2, 2004 Author Share Posted August 2, 2004 Well the kit does supply an extra pump that you have to mount on the washer bottle. If it was me I would just put water in it cause I sure as hell dont want flameable fluid(washer fluid) spraying all over my engine bay! Guy Quote Link to comment Share on other sites More sharing options...
