car wont stay running
anyone noe my problem. i seem to think its my fuel pump. somehow im not gettin enuff fuel to keep the car running. it'll run untill theres not enuff presure in the fuel rail to feed the injectors. Its like the rpm goes down as if im running out of fuel. like if i was giving it gas, the rpms jus slowly fall and then the car jus stalls.
could it be my relays? or could it be a wiring problem.
so my problem is solved. it was the most simple thing. It was the oil pressure switch.
Now i have another problem. Didnt have this problem untill i changed my injector clips/plugs. Now it seems to run really rich. It runs rough and a lot of smoke. Could it be the fuel pressure regulator? wat do u guys think?
It seems that when i run the car, then unplug the fuel pump for a few secs, it starts to run smooth. So i continuiously tap the fule pump and the car ran jus fine.
