Guest hwk60 Posted August 15, 2004 Share Posted August 15, 2004 The shaft in the car i'm buying is shot, i'd like to get a good custom shaft and the best U joints for my set up. Any help would be appreciated. Thanks. Tony Quote Link to comment Share on other sites More sharing options...
80LS1T Posted August 15, 2004 Share Posted August 15, 2004 Any good driveline or machine shop can make a driveshaft. All you have to do is give them the measurements that they want. Guy Quote Link to comment Share on other sites More sharing options...
Guest hwk60 Posted August 16, 2004 Share Posted August 16, 2004 wish i knew the correct measurements, guess i'll put the stanley tape to the old busted shaft and hope it was the right length. Quote Link to comment Share on other sites More sharing options...
80LS1T Posted August 17, 2004 Share Posted August 17, 2004 If you call the machine shop they will ask you for a set of dimensions. When I had mine made they asked for the center of the U-joints on the yoke end(tranny side) to the center of the u-joints on the flange end(differental side). If you can get the yoke and the flange off the old driveshaft you can do the same as me. Just put the yoke all the way in the tranny then pull it out 1/2"- 3/4" and attach the flange to the diff. Then measure from center to center where the u-joint would be. That is how they told me to measure mine. Guy Quote Link to comment Share on other sites More sharing options...
fl327 Posted August 17, 2004 Share Posted August 17, 2004 take that driveshaft to any driveline shop and just get the factory v8 ujoints installed at both ends, they go a long way in a light car. Quote Link to comment Share on other sites More sharing options...
homerneedspeed Posted August 18, 2004 Share Posted August 18, 2004 what swap kit and trans are you using? i have a driveshaft for a th350, jtr swap with r200 companion flange i'd let go for 125 obo. it has 1000 miles on it and never vibrated, it's a brand new shaft with all new parts i bought for 250 a year ago. Quote Link to comment Share on other sites More sharing options...
Guest hwk60 Posted August 20, 2004 Share Posted August 20, 2004 Ready to buy! i sent you a pm. Lets talk! Quote Link to comment Share on other sites More sharing options...
