Forrest Posted August 20, 2004 Share Posted August 20, 2004 Hey guys, I couldn't find any recommendations in this forum for going from hardline to braided hose that didn't include replacing the hardline with 3/8" line. Does anyone know where I could get 6AN to 5/16ths compression fitting? Or did anyone find a different way to solve this problem? Also, off topic, I'm having trouble finding brass vacuum t's and 6AN to barbed fittings, if anyone knows where to pick those up. Thanks, -Forrest PS I didn't have any luck at Jegs or Summit, but if you have part numbers, hook me up. Quote Link to comment Share on other sites More sharing options...
evildky Posted August 21, 2004 Share Posted August 21, 2004 the barb fittings are tricky, I used 6an presslock adapters, they are kinda big I used a touch of wd40 to get the hose to slide over the fitting but it worked and they are readilly available at any speed shop, or summit/jegs as for the brass "T"'s I go to the hardware store and buy a brass block and the correct nipples and screw them together, but I am not sure why you need a vacume "T" stock manifolds seem to be overly well equipped with fittings Quote Link to comment Share on other sites More sharing options...
