Clutch master to slave/ hose
Getting things together here...
JTR sayts the hose for the clutch master cylinder to the slave cylinder using a WC T-5 should be 24 inches. I'm having a custom hose made and want YOUR opinion on hose length. JTR position, 350, T-5. Engine not in car YET. D-day approaching 1/25/03!!! I cant wait!!!
David
Guest Anonymous
Well let me start with,I just did this and the hose wont be the problem,the bellhousing you use will make a great difference in this project of yours. If you use the stock chevy T5 b/housing then you will need to use the stock slave cyl. aswell and this is a prob because of the two different size bores on the slave and the master,the slave being 7/8" & the mastr. being 5/8".The problem here is that the master will not push the slave quit far enough to disingage the clutch,the cure I found was to use a 7/8"HOWE master from summit racing for about $60.00 and it will almost fit perfectly into the firewall,a small amount of deburing may be the only work to install it. Now there are a few shifter probs aswell when using the stock b/housing so if you want more info please E mail me and I will give you my # so you can call me,good luck.
Wayne,73 240 Z8T,thats right,she's a TURBO.
Guest Anonymous
Heres another thing that I forgot to mention,the stock chevy slave is plastic and wo'nt accept a normal hose so you either need to get the stock hose assymbly and modify it or do what I did,tap the plastic opening on the slave to accept a 1/8" pipe fitting and use a 1/8"pipe to number 4 an fitting thus creating your own style of hose,call me and if you want I will do it for you,it works great.I say that now
The Corvette bell housing doesn't mount the trans at the 14 degree angle like the Camaro AND uses an aluminum slave cylinder. All you have to do is remove the stop under the cliutch pedal (welded to the floor pan) and it will work fine with the stock master cylinder. 2thumbs.gif
Ditto what FlameZWayne Said about the 3/4" master. I learned this the hard way. I used a 7/8" Tilton. Bolted right up. I also modified the Camaro plastic slave same way, the jtr way. Just be very careful when you drill and tap. Take it completely apart and clean it out completely when your done drilling and taping. I used a drill press, made it much easier. And, of coarse, don't over tighten the fitting. I used an off-the-shelf 24" XRP steel braided line with the fittings attached. Think it was about $18. Straight on one end and a 90* on the other.
Here's a pic that might be helpful.
Good info guys. I have the 7/8 Tilton unit (what, don't you think I read old posts? haha)
Dan (thanks for the pic) are you running a T-5?) If so could you measure or do you remember the hose length.
The shop I'm using for this said they would have NO PROBLEM connecting to the slave I've dismantled the slave and I cut the nylon (sp) tubing off the nipple.
Bottom line, I need the hose length I'm guessing 26" will work I just don't want to buy 2 hoses.
Thanks,
ds
For Dan:
I like your throttle linkage. What throttle cable and firewall bracket did you use? I can't see in the picture what cable bracket you used on the carb end. Do you have a photo of the whole setup?
Thanks
Miles
