engine block prep.
here read. it will help, if you don,t read the links the time and effort is wasted, its worth your time and effort to learn the tips
http://www.sa-motorsports.com/blockdiy/blkdiy.htm
http://www.hardblok.com/info.html
http://www.findarticles.com/cf_0/m1185/n8_v32/21148174/p1/ar ticle.jhtml?term=chevy+%2Bcombustion+%2Bchamber+design
http://www.speedomotive.com/building%20tips.htm
http://www.se-r.net/engine/block_prep.html
http://racerhelp.com/article_racing-10.html
now in addition to that info , heres what I do
(1) get the block totally cleaned, DEGREASED and CHECKED by a GOOD MACHINE SHOP BEFORE INVESTING MONEY IN IT!
(2) have new cam bearings and freeze plugs , oil plugs,installed only after all other machine work is done and after a extensive recleaning of all the oil passages just prior to starting assembly
(3) screens over the oil drain back holes are a good idea ONLY if your willing to change oil and filters very frequently
(4) several powerfull magnets in the oil pan and one in the rear of each cylinderhead to trap small metal parts is EXCELLENT INSURANCE
(5) polishing and smoothing the valve edges and combustion chambers helps prevent detonation
(6)never fill the water passages higher than the bottom of the freeze plug holes on a street engine
(7) 7 or more qt oil pans with BAFFLES AND A WINDAGE SCREEN like MILODON MAKES are a GREAT IDEA
(8)personally I use standard voluum BIG BLOCK OIL PUMPS or high voluum sbc oil pumps in those 7 qt plus oil pans
(9) ALWAYS READ AND FOLLOW THE MANUFACTURERS INSTRUCTIONS UNLESS YOUR TRUELY POSSITIVE YOU KNOW BETTER
(10) measure everthing at least 3 times and get the clearances CORRECT, not close!
(11) use all ARP studs and bolts and get EVERYTHING BALLANCED, take your time ,ask questions and do it correctly the first time
btw heres where you get the magnets and use no smaller than 1/8" grid screen EPOXYed IN PLACE,
http://www.wondermagnet.com/dev/magnets.html
(I use the #1,2 and #42)
Excellent advise, Grumpyvette. I lot of engine builder forget about the FINER things in in doing a good build. I'm very particular on who's machine shop I'm going to also. Alot of us love buildng motor, but hate rebuilding them 200 miles down the road, just because we neglected to .....do attention to detail. One thing I would like to add/and your opinon. Is the use of (I forgot the name)that stuff you paint in the valley to assist oil drain back. I think I got it for The Eastwood Co.
Helldrives
next time you have a bare block with the freeze plugs removed ready to take to a machine shop for boiling out look carefully into the area around the outside of the cylinders inside the block where the coolent normally flows, youll notice that the bottom of the freeze plug holes are about 1/3 up the cylinder bore length, most of the engines heat is generated in the upper 1/2 of the cylinder and the heads so filling only the lower 1/3 of the coolent passage around the cylinders strengthens the cylinder walls but if DONE CORRECTLY has little effect on cooling efficiency
