Guest cs14silvia Posted August 29, 2004 Share Posted August 29, 2004 got this problem, cant shift to 5th and reverse gears. 1 to 4 are fine clutch is half gone, just bleed the clutch cylinders. is it the selector ? or its just the clutch Quote Link to comment Share on other sites More sharing options...
datsunlover Posted August 29, 2004 Share Posted August 29, 2004 Probly a trany issue.. if the clutch was the problem, you'd have trouble in evry gear. I'd guess the shift fork (is that the part's name?) for 5th/rev might be bent.. or possibly you've just lost 5th and reverse gears.. Quote Link to comment Share on other sites More sharing options...
fl327 Posted August 29, 2004 Share Posted August 29, 2004 I believe you blew fifth gear, which on the early trannies shares the same rail as reverse. Time for rebuild or new trans. Quote Link to comment Share on other sites More sharing options...
Guest cs14silvia Posted August 31, 2004 Share Posted August 31, 2004 funny thing is sometimes it goes in, sometimes it doesnt 1-4 gears most of the time work but sometimes dont. arrr~ rebuild...probably time for RB thanks guys Quote Link to comment Share on other sites More sharing options...
