DAT240Z Posted August 30, 2004 Share Posted August 30, 2004 I have an 83 turbo swaped in to my 240z well I upgraded to the 370cc injestoer a while and turn the AFM wheel 18 tooth like i have read on here but could not get the car to run right, it would run till it hit 4k rpm and that stall so i pulled the 370cc and went back to the stock 270cc injector. i still could not get the car to run over 4k rpm even after I set the AFM back where it was before I installed the 370cc. I got another AFM of E-bay and installed it today and the car will start but not run more that a second or two. I notice if I were to hold the key in the on position the car would run, so I put the old AFM back in but the same thing happends and I have to hold the key on for it to run. I than relpaced the the hold switch with a new one and I still have to hold the key in the run position to get the car to run. I should have left well enough alone as the car ran great before I installed the new 370cc injectors and messed with the AFM. Can anyone help Thanks Quote Link to comment Share on other sites More sharing options...
lifegrddude Posted August 31, 2004 Share Posted August 31, 2004 I had mine adjusted at 18 teeth before, but it would sputter past 4800 revs. I adjusted the tension to 12 teeth and it's been fine ever since. This is with 370cc injectors btw. John 82ZXT Quote Link to comment Share on other sites More sharing options...
DAT240Z Posted August 31, 2004 Author Share Posted August 31, 2004 the pump shut off after 2 seconds of running. It will only run if I was to hold the in the start position. Can anyone tell me how the AFM works in ralation to the fuel pump? Quote Link to comment Share on other sites More sharing options...
