Need help IDing my cam - think it a Schneider but ...
heavy85
It's in a P79 head from L28 and I was told it's a 'mild cam' when I bought the car. It has a maltese cross on the end with a fancy script S with what appears to be a part # 26119 (this part number is not on the Schneider web site but they do use a maltese cross in their logo). Also stamped on the end is 270.80F with an R and an M stamped on either side of the dowel pin. I'm thinking this means 270 deg / 280 deg but that's just speculation. Not sure what the letter mean though. Lift (measured difference between max height and the base circle) is between .292" and .302" which at first I thought was low but multiply by rocker ratio of ~1.5 and the lift would be between .438" and .453" at the valve. Anyone know if I'm on the right path here? Is it a 270 / 280 deg .450 lift Schneider cam?
Thanks
Cameron
