Guest Cronic Posted September 9, 2004 Share Posted September 9, 2004 My relay or something is going bad. Sometimes when the car sits over night, it takes a good 15-20 mins for the pump to turn on when the key is in the ON position. Can I just run the pump to a 12V switch? Like to the ignition switch? Or just a normal switch? Can I bypass the relay all together? Quote Link to comment Share on other sites More sharing options...
Guest Cronic Posted September 20, 2004 Share Posted September 20, 2004 Anyone?? Quote Link to comment Share on other sites More sharing options...
mark Posted September 20, 2004 Share Posted September 20, 2004 Check the voltage at the pump to confirm that the pump is not getting power. Mark Quote Link to comment Share on other sites More sharing options...
dapiper Posted September 21, 2004 Share Posted September 21, 2004 Should rewire fuel pump direct to batt thru relay and fuse. Use AWG 12 to keep resis low. Pump can draw 10 amp when working against backpress from boost. Quote Link to comment Share on other sites More sharing options...
Guest Cronic Posted September 21, 2004 Share Posted September 21, 2004 Ran directly to batery, pump runs constant, does not prime... should it do this? Car also would not start when pump was directly connected to batery. eventually, the pump came on w/ the key in the ON position. Gave me problems this morning too, but I let it sit for 30 mins in the ON position, and it came back on. Hardwire to bat. does not work!? Why? Quote Link to comment Share on other sites More sharing options...
dapiper Posted September 22, 2004 Share Posted September 22, 2004 Maybe pump internals corroded from crud in tank and/or bushings bad. Pump should run off batt. Quote Link to comment Share on other sites More sharing options...
Guest Cronic Posted September 24, 2004 Share Posted September 24, 2004 The pump runs, and pulls fuel. However it doesn't stop running. it doesnt allow the car to crank cause it just keeps dumping in fuel? Quote Link to comment Share on other sites More sharing options...
Guest fattyjay22 Posted September 27, 2004 Share Posted September 27, 2004 I had the EXACT same problem, but my pump would never come on!!! I went the hot wire direction, then realized I was running VERY LEAN!!! I found ou mine was the fuel contact point in the AFM. I just douced it with some electrical carbon cleaner and it has never run better!!!! HOpe this helps. PM me if you have any questions!! Good luck!! Quote Link to comment Share on other sites More sharing options...
Guest Cronic Posted September 28, 2004 Share Posted September 28, 2004 Interesting.. the MAF determines the fuel pump? Please let me know exactly what you did, and where you're talking about. Thanks! Quote Link to comment Share on other sites More sharing options...
