putting a turbo clutch and flywheel in a N/A tranny
jtmny1999
:roll: If I remember right, you will need to use the fork and throw-out from the clutch you are putting in. You will find out that it will be real hard to shift with the NA parts. The larger clutch has a different lenght to it and you need the parts from it. I found out about it the hard way. Put a Centerforce clutch in and had to put in a smaller collar. When I replaced the clutch and put back in a stock clutch. It would not shift with the smaller collar in it. Had to pull it apart and replace it just before a race. Good Luck, Rich.
Remember that the turbo flywheel and clutch was also installed in NA 280z 2+2 with the nissan tranny. You need the correct fork for your transmission, depending if you are using the Nissan NA or T5. If you check the TO bearing and sleeve, I believe that the later cars are all the same.
Doug
