subframe connectors
From the install photos it appears that Pete's subframe connector rail design requires 2 "Slots" cut in the floorpans. Has anyone made them that don't require cutting the floor pan panels? i.e. they set flush with the bottom of the floor.
Also, can they be built completely bolt-in for the welding-impaired?
  Quote
Also' date=' can they be built completely bolt-in for the welding-impaired?[/quote']
Pete used 2 X 3 tubing, and cut the floor pan. Just use 1 X 3 and set it flush w/floor. I wouldn't bolt it in, not strong enough
